How can I define the length of a flange in a sheet metal part? In other words, I would like a flange to run a definitive length along the edge of a part, not the entire edge of a part.
I apologize if this has been asked before. I did a brief search of the forum and could not find a solution.
Solved by JDMather. Go to Solution.
Attach your file here.
Expand the dialog box and set Width or desired Offset distance from each end.
The CADWhisperer YouTube Channel
Thanks for this post from a long time ago. Appreciate it - made my life a lot easier today!!
JD you're the best.
Hi, I'm trying to do this same thing in Fusion 360 (2020). (Create a flange that only bends a specified distance on an edge.) Is this possible?
Thank you!
See Image.
