Inventor Forum
Sheet Metal Face Thickness
3 REPLIES 3
Cadmanto
6592 Views, 3 Replies
When you use the face command in sheet metal how and where is the thickness determined
and changed?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
3 REPLIES 3
Cadmanto
in reply to: Cadmanto
Nevermind.  I found it under the setup command.
Seems like a lot of extra steps.
Best Regards,
Scott McFadden
SBix26
It's only a lot of extra steps if you don't have a library of sheet metal rules to choose from.  What did you have for choices under "Sheet Metal Rule"?
Cadmanto
in reply to: SBix26
Sam,
I only have two "Sheet Metal Rules"  The out of the box ones.  As I have worked through creating sheet metal parts I have discovered the rules and realized that the rules could make this a lot easier,  I know the more I develop I am sure the more rules I will create.
Best Regards,
Scott McFadden
