Hello all.
WARNING:I am new to ilogic and creating code.
I have an assembly containing several sheet metal parts. I have a spreadsheet that needs the length and width extents (stretchouts) for each of the sheet metal parts in the assembly.
I created rules that that will update the custom iprops and the user parameter at the part level.
My problem is this: I can not get the new length and width extents into the assembly custom iprops or user parameters without opening and and updating the part models individually.
JPG 1: this is the ilogic that populates the user parameters and custom iproperties at the assembly, but it wont work.
JPG 3+4: this is the ilogic at the part level that populates the user parameter length and width extents. This is the information I need to get into the assembly but I dont know how.
JPG 1 (AT ASSEMBLY LEVEL)
JPG3 (AT PART LEVEL)
JPG4 (AT PART LEVEL)
TO RECAP: I NEED SHEET METAL EXTENTS TO FILTER UP FROM THE PART LEVEL TO THE ASSEMBLY LEVEL.
THANKS FOR ANY HELP
DON
@PaulMunford wrote:
So - you need an ilogic routine that opens each part file in an assembly, runs the 'create unfolded part'command, and then saves and closes each part...
I don't have this routine, but I want it 😉 I hope that Curtis Waguespack is reading this!
I'll see what I can come up with, but it might take a few days for me to get back to it.
In the mean time, this might be of interest:
THANKS GUYS....FYI,,,,I CAN GET THE EXTENTS INFO AT THE PART LEVEL.....I JUST CANT SEEM TO PULL IT INTO THE ASSEMBLY..SNIFF...
