Inventor Forum
Sheet Metal Drum Cutout
8 REPLIES 8
Message 1 of 9
1377 Views, 8 Replies
I am working on a new way to model sheet metal drums we currently manufacture at my company. The flat patterns are typically cutout on a Trumph machine, then rolled and spot welded along a seam on the ends. The drums also will have a shaped cutout located in the middle of the part. I have attached one drum with the cutout, file 7501_DRUM_TEST.ipt The flat pattern looks perfect, but the "folded" model has edge problems on the interior shaped cutout where the radiuses intersect with straight lines (see model file).
Thanks for any help!
Inventor 2010 Professional, SP2
8 REPLIES 8
Message 2 of 9
yannick3
Hi
It's look a like a bug with refold feature
It's fix with 2011
Yannick Edited by: Yannick3 on May 12, 2010 11:00 AM
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Message 3 of 9
not sure why it's doing that, but if you remove he the joggle bend from the unfold selection the issue is resolved.
Message 4 of 9
see attached
Message 5 of 9
Works great, thanks!
Message 6 of 9
anyah
hello I'm working a project and I want to simulate plate embedded in an inventor as I can do this is
the picture of what I want to simulate
Message 7 of 9
JDMather
in reply to: anyah
Attach the file here of what you created so far.
I would have started a new thread for this new problem.
Message 8 of 9
anyah
Hola
me pueden ayudar quiero simular un estampado en chapa como puedo realizar la simulacion de que el estampado de una media pelota y con l perforacion  me pueden ayudar de como se puede realizar gracias por su ayuda
Message 9 of 9
JDMather
in reply to: JDMather
Another (easier) method.
I didn't bother to fix up the constraints on the first sketch.
