Inventor Forum
Sheet metal development
3 REPLIES 3
mrattray
1736 Views, 3 Replies
This is what I'm trying to build:
I know Inventor can't flatten this, and that's OK. I've managed to get a flat pattern out of an old AutoCAD based progam called "Plate 'N' Sheet". I'm at a point where I have a good 3D model and a flat pattern I can send to the laser. The problem is, how do I help my fab guys build it? They want me to give them brake notches so they can bend it up in a standard press brake. I can do that in AutoCAD, but I don't know where to put them. Plate 'N' Sheet only gives me one bend line per panel.
What I'm really looking for here isn't really Inventor help, but rather some general sheet metal working help. Is ther any words of wisdom, tricks of the trade, or handy links anyone would like to share? Thanks in advance!
Mike (not Matt) Rattray
3 REPLIES 3
JDMather
in reply to: mrattray
When I look at that I think, "How will they make this?  Won't they just make it in the simple rectangular form and the ends and twist.
If that is the case then you don't need the flat of a twisted part, it is a flat of a basically rectangular C shaped Contoured Flange.
If this is made in house you can ask your fabricators if this idea will work.
The CADWhisperer YouTube Channel
alewer
See attached. It's ugly, but I it flattens. You can smooth it out by taking more "steps" than I did.
Folded/Flat:
I'm sure there is a more elegant solution, but this one at least proves it's possible. If you come up with a cleaner method, post your solution. Good luck!
mrattray
in reply to: alewer
Thanks! I refined your model by tweaking the dimensions and adding a lot more "panels". I'm going to have metal fab take a stab at a shortened test piece tomorrow morning to see if we're going to get the final shape we actually need.
This is an interesting approach, very tedious, but interesting. Maybe when I have some time I can refine this process, as I'm sure as soon as sales finds out we were actually able to make this P.O.S. they'll be in a scramble to sell every god forsaken twisted up pile of dog turds they can dream up.
Thanks, again!
