Inventor Forum
sheet metal defaults "Use Thickness from Rule" - ilogic
2 REPLIES 2
celesiob
1193 Views, 2 Replies
hello forum friends, anyone know a rule to check if this dialog box sheet metal defaults "Use Thickness from Rule" is checked, and checked a rule to automatically clear since using a rule amending the plate thickness but if the box is checked catastrophic error occurs, and unchecking the rule works as expected. thank you in advance for the help already.
2 REPLIES 2
Yijiang.Cai
in reply to: celesiob
Please see the rule below, which is used to check whether the sheet metal defaults "Use Thickness from Rule" is checked -
Sub Main()
    Dim oDoc As PartDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As SheetMetalComponentDefinition
    oCompDef = oDoc.ComponentDefinition
    If oCompDef.UseSheetMetalStyleThickness = True Then
        MessageBox.Show("Checked", "Title")
    Else
        MessageBox.Show("Unchecked", "Title")
    End If
End Sub
Hope it helpful for you!
River Cai
Inventor Quality Assurance Team
Email: River-Yijiang.Cai@autodesk.com
celesiob
in reply to: Yijiang.Cai
Thank Yijiang.Cai with the rule suggested solved the problem.
