Inventor Forum
Sheet Metal Cylinder
6 REPLIES 6
F.Goncalves
416 Views, 6 Replies
Hi, I want to make an sheet metal cylinder but the ends of the plate must be chamfred like this:
But, when I do the chamfers with the plate flat, when i try to fold it, it doesnt fold the chamfers...
anyone knows how to do this?
thanks!
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
F.Goncalves
6 REPLIES 6
Mario428
in reply to: F.Goncalves
Do Not use the chamfer under the "sheet metal" tab, use the one under " 3dmodel " and do it when the part is in rolled condition not on the flat pattern.
It will come thru fine but will show up in your flat pattern
JDMather
Something like this?
F.Goncalves
in reply to: JDMather
are you able to save in Inventor 2012? I can't open :S
If not, maybe tomorow I'll install 2015 version and see if this what i been looking for.
thanks for the help!!
F.Goncalves
JDMather
Extrude your cylinder with desired wall thickness.
Extrude-Cut the angled slot.
IgorMir
Here is a one method. Please see the attached. IV2010 file.
Cheers,
Igor.
thanks!
Web: www.meqc.com.au
F.Goncalves
in reply to: IgorMir
yes! it's exactly this. thanks!
I'll try to understand the steps you made.
thanks!
F.Goncalves
