Inventor Forum
Sheet Metal Cut Error
2 REPLIES 2
209 Views, 2 Replies
I have attempted to make a cut, wrapped around a bend.
The following error occurs.
If I do not wrap the cut around there is no error.
How do you work out what part of the sketch is the problem?
[WARNING] S-RearDoubler.ipt: Errors occurred during update [r:\core\rd\Main\Component.cpp, line 497]
[ERROR] Cut5: Could not build this Cut [r:\core\rd\Main\Feature.cpp, line 202]
[ERROR] AGlib data out of range [r:\core\mi\helpers.cpp, line 623]
[ERROR] null pointer to face given [r:\core\mi\helpers.cpp, line 623]
[ERROR] null pointer to entity given [r:\core\mi\helpers.cpp, line 623]
[ERROR] Sheet Metal: Cut Edit failed. [r:\application\mbui\Request\MBxCutRequest.cpp, line 2776]
2 REPLIES 2
One place to start is to make sure that the cut doesnt start or end inside a bending zone when the flat pattern is projected to the sketch. I know this will not work.
Can you post the file to autodesk.inventor.customer.files? Contrary to what
RHarriman wrote, there aren't restrictions to starting or ending cuts in the
bend zone.
Loren Jahraus
Autodesk Inventor Workflow Team
"frisbdave" wrote in message
news:f1a29b8.-1@WebX.maYIadrTaRb...
