I have attempted to make a cut, wrapped around a bend.
The following error occurs.
If I do not wrap the cut around there is no error.
How do you work out what part of the sketch is the problem?
[WARNING] S-RearDoubler.ipt: Errors occurred during update
[r:\core\rd\Main\Component.cpp, line 497]
[ERROR] Cut5: Could not build this Cut [r:\core\rd\Main\Feature.cpp, line 202]
[ERROR] AGlib data out of range [r:\core\mi\helpers.cpp, line 623]
[ERROR] null pointer to face given [r:\core\mi\helpers.cpp, line 623]
[ERROR] null pointer to entity given [r:\core\mi\helpers.cpp, line 623]
[ERROR] Sheet Metal: Cut Edit failed. [r:\application\mbui\Request\MBxCutRequest.cpp, line 2776]
