Inventor General Discussion
Active Member
Hidayah
Message 1 of 10 (979 Views)
sheet metal corner joint
979 Views, 9 Replies
01-13-2013 05:43 PM
Dear All,
Can anyone help me on this?
How to joint this corner together for becoming 45degree corner shape?
See attachment and Inventor file.
blair
Message 2 of 10 (972 Views)
Re: sheet metal corner joint
01-13-2013 06:06 PM in reply to: Hidayah
Expand the Hem command box and use the offset to create the hems. Then use the Corner command. I did a quick change to your base sketch to get the (sides) longer.
The sketch is completely unconstrained, not good modeling practices.
IV2015 up2 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Active Member
Hidayah
Message 3 of 10 (960 Views)
01-13-2013 06:46 PM in reply to: blair
Thanks a lots for the help! :smileyvery-happy:
JDMather
Message 4 of 10 (922 Views)
01-14-2013 07:46 AM in reply to: Hidayah
I think you are doing too much work.
There is an easier way.
First thing I noticed is that your Sketch1 is not constrained.
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
brendan.henderson
Message 5 of 10 (873 Views)
01-14-2013 06:59 PM in reply to: JDMather
I always enjoy you solutions. Buggered if I know how you did it with only 2 features though! Mind sharing the secret JD?
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2014 PDS Premium SP2 Update 1, Vault Professional 2014 Subs Release 1 & Update 1
Please use "Accept as Solution" & give "Kudos" if this response helped you.
blair
Message 6 of 10 (863 Views)
01-14-2013 09:18 PM in reply to: brendan.henderson
here is a better one
Win7-64
*Pro
sbixler
Message 7 of 10 (839 Views)
01-15-2013 04:36 AM in reply to: brendan.henderson
Here's one with the two features similar to JD's method (I presume).  This is done in 2013, so the OP (using 2010) won't be able to open it.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Valued Mentor
BLHDrafting
Message 8 of 10 (819 Views)
01-15-2013 12:41 PM in reply to: sbixler
Sam and Blair, many thanks.
Good old CONTOUR FLANGE. Never new it could do that. Touchy in the order or operations and in the skecth geometry (had Bendradius*2 for HEM width but just had too keep trying to get it to work).
Maybe 1 for the developers but the cut in the FACE side of the part isn't needed for manufacturing this part. This only occurs when you have the CT as an extension to the extents of the FACE. If the FACE includes the length of the HEM then these extra cuts are not generated.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
JDMather
Message 9 of 10 (815 Views)
01-15-2013 12:51 PM in reply to: BLHDrafting
Unfortunately the OP had unconstrained sketches in the original post and only visits here about once a year and apparently didn't see the better solution.
*Pro
sbixler
Message 10 of 10 (781 Views)
01-16-2013 04:47 AM in reply to: BLHDrafting
You're right about the unneccessary cut on the face.  This one eliminates that, but I'm not too pleased with the way it opened up the ends of the miters.  Oddly enough, the preview while creating or editing the Contour Flange feature looks much better than the finished product:Sheet Metal Corner 1.PNG
The only way I found to make it look "right" is to choose Arc Weld for the corner relief shape.
Sam B
