Inventor Forum
sheet metal corner joint
9 REPLIES 9
Message 1 of 10
Hidayah
2469 Views, 9 Replies
Dear All,
Can anyone help me on this?
How to joint this corner together for becoming 45degree corner shape?
See attachment and Inventor file.
9 REPLIES 9
Message 2 of 10
blair
in reply to: Hidayah
Expand the Hem command box and use the offset to create the hems. Then use the Corner command. I did a quick change to your base sketch to get the (sides) longer.
The sketch is completely unconstrained, not good modeling practices.
Delta Tau Chi ΔΤΧ
Message 3 of 10
Hidayah
in reply to: blair
Thanks a lots for the help! Smiley Very Happy
Message 4 of 10
JDMather
I think you are doing too much work.
There is an easier way.
First thing I noticed is that your Sketch1 is not constrained.
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
The CADWhisperer YouTube Channel
Message 5 of 10
I always enjoy you solutions. Buggered if I know how you did it with only 2 features though! Mind sharing the secret JD?
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 6 of 10
blair
in reply to: brendan.henderson
here is a better one
Delta Tau Chi ΔΤΧ
Message 7 of 10
SBix26
Here's one with the two features similar to JD's method (I presume).  This is done in 2013, so the OP (using 2010) won't be able to open it.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 8 of 10
BLHDrafting
in reply to: SBix26
Sam and Blair, many thanks.
Good old CONTOUR FLANGE. Never new it could do that. Touchy in the order or operations and in the skecth geometry (had Bendradius*2 for HEM width but just had too keep trying to get it to work).
Maybe 1 for the developers but the cut in the FACE side of the part isn't needed for manufacturing this part. This only occurs when you have the CT as an extension to the extents of the FACE. If the FACE includes the length of the HEM then these extra cuts are not generated.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
Message 9 of 10
JDMather
in reply to: BLHDrafting
Unfortunately the OP had unconstrained sketches in the original post and only visits here about once a year and apparently didn't see the better solution.
Message 10 of 10
SBix26
You're right about the unneccessary cut on the face.  This one eliminates that, but I'm not too pleased with the way it opened up the ends of the miters.  Oddly enough, the preview while creating or editing the Contour Flange feature looks much better than the finished product:Sheet Metal Corner 1.PNG
The only way I found to make it look "right" is to choose Arc Weld for the corner relief shape.
Sam B
