When I create a cone the developement is fine ( a triangular(ish) blank).
If a small swage is added to the top of the cone & 'Contor Roll' applied - the whole blank becomes rectangular!
Is an addin available to cope with swages?
MES
Hi!
In real world, this last operation consist is a plastic deformation, so, by deffinition it will occur a variation in the thickness, it's not a bend, so the inventor can´t calculate the flat pattern.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Thanks for the feedback.
Is there any software or Inventor add-in which will cope with swages being added to sheet metal parts?
MES
