Howdy all,
Looking a little help on this sheet metal part. I left a sketch open so you can see the area I want to work with (aprox).
I am looking to take this 'boxed' (sketch) area and bend it down 15° using the inner edge (dimensioned 75mm from the part edge). I realize this will likely result is the top and bottom edges being cut away from the main body to allow for the bend, but that is all good.
I tried a few ways and couldnt get it to do what I wanted.Wondered if I could get some experienced help.
Tks! 🙂
Solved by johnsonshiue. Go to Solution.
Hi Randy,
Could you please post a screen shot of your model? I am with older inventor release.
Cheers,
Igor.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Hi! I guess you are looking for a way to bend a face by tearing the adjacent bend zones. Geometry modeler usually likes to keep topological continuity before and after body transformation. You will need to prep the tearing manually before creating the bend. Please take a look at the attached part. Is it consistent with what you are after?
Thanks!
That was the exact thing I was trying to accomplish. I have never used the split tool before, good to know how it works and for what.
I also didnt realize you had to 'prep' the material before hand, I thot the sheet metal tools auto-'sheared'. But my exposure to sheet metal is quite limited at the moment.
Thanks for the help! 🙂
Hi! Most softwares are good at what they were designed to do but they all have limitations. The problem is that the limitations sometimes are not explicit or easy to understand. Inventor generally does a good job mimicking real world behaviors. For cases like this, the user's intervention would be a must unfortunately.
Thanks!
Alternative solution...
1) Sheetmetal cut with "Project Flat Pattern" to project just the adjacent bends.
2) Flange. However, this will also require some measuring to match the flange to the rest of the part edging when in the blank.
-Brian
