I played with this a little bit, and I ran into the same problems. It looks
like we are running into problems with the small surfaces that are created
for the bend zone. I was able to get close to what you need by initially
creating the bend at 2 degrees and .015 bend radius. I could then reduce the
bend angle to .4 degrees and then the bend radius to .005. It seems that it
is easier to reduce existing surfaces than to create them from scratch.
Loren Jahraus
Autodesk Inventor Workflow Team
"Ron Crain" wrote in message
news:2D4A5DFED42EEFD28E48B7E92DC5CD4E@in.WebX.maYIadrTaRb...
> I have run up against what I think is a resolution problem.
> Now nobody laugh at what I'm trying to do - I need to do this for very
good
> reasons .
> I have a sheet metal part .001" thick and I'm trying to place a bend in
it
> using a bend-line. I can bend it 2 degrees without a problem, but when I
> get down to 1 degree or less I get errors:
> "Could not build this fold... Modeling failure while merging the results
of
> face-face intersection."
> . Has anyone tried things this small before? I need the bend
to
> be 0.4 degrees - yes, that's right 🙂
