Inventor Forum
Sheet Metal (again!)
49 REPLIES 49
Message 1 of 50
Talayoe
740 Views, 49 Replies
Something so simple...  I am sure I am complicating the hell out of it...and making a mess to boot.
Have a part, rectangular 3.5 heigh x 46" long. I want to roll 270° it so that the center has a 10.875 rad.
I got one variation of it to go while tinkering but it took me about 8 steps. I hope this makes someone laugh cause its really annoying. Gotta take a sheet metal class or something meh thinks.
Any help/ideas or a quick ipt of somthing of the similar would be a wonderous help.
tks much! =]
-Randy
Inventor 2017 PDS
49 REPLIES 49
Message 2 of 50
JDMather
in reply to: Talayoe
Why don't you make it in finished form?
Not sure I understand the dimensions.
Message 3 of 50
Talayoe
in reply to: JDMather
Sorry, I gave the simplified version of it. It actually has a 30° on one end and loooong chamfer on the other.
Attached a copy of simplified version.
tks for quick response JD.
-Randy
Inventor 2017 PDS
Message 4 of 50
WHolzwarth
Normally Jeffrey is asking for files. I'm helping out.
😉 Ok, done 1 minute ago
Walter Holzwarth
Message 5 of 50
JDMather
Where did the 46 come from? Or the 270°? Or the R10.875?  Something doesn't seem right?
Message 6 of 50
Talayoe
Me again! 😉
JD, sorry. didnt see the picture when I responded with the attachment. You have the center correct for the rad but the opening at the bottom should actually be 60°, not 10°, which conflicts with my first post only because 360 - 60 = 270 in my mind (apparently). Should have been 300° around... oops. lol Sorry
-Randy
Inventor 2017 PDS
Message 7 of 50
Talayoe
Hi JD,
Looks like we both posted at the same time but you beat me by a moment;
This is what I posted
Me again!
-Randy
Inventor 2017 PDS
Message 8 of 50
JDMather
Either I am missing something - or your dimensions still don't make sense (see attached).
Have you deducted for significant stretching in your flat?
Message 9 of 50
blair
Since I can't attach files while at work, I would just start with the flat plate the correct size (since it's given) place a line on the mid point and bend the one half the radius and 1/2 of the total angle. Place a sketch on line on the flat and bend the other half of the plate the radius and 1/2 of the required angle.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 10 of 50
jletcher
If I understand.....
Message 11 of 50
JDMather
in reply to: jletcher
Here is image of my "solution".
Message 12 of 50
Talayoe
jletcher,
That is exactly what I was looking for and figuring...meaning I thot there should be a way to just create a part and bend it like you did. This being said, when I tried to re-create this part I noticed that my 'bend part' is grey out. I am not sure why this is tho. Any thoughts?
JD and others, thank you for the input and ideas. I tend to stray away from the 3D sketches as I dont fully understand them yet, but it did get the point across. And to clarify, I must have been on something when I wrote the inital post. It was 30° off the center line that making the total rotation 240°. I am sure I can confuse this a little more if I say anything else. My bad.
-Randy
Inventor 2017 PDS
Message 13 of 50
jletcher
after making the sheet metal face convert to regular part, use the bend option then convert back to sheet metal..
Message 14 of 50
rdyson
Note that "bend part" doesn't calculate bend deduction
PDSU 2016
Message 15 of 50
Talayoe
in reply to: rdyson
Rdyson,
For this particular component it wouldnt make any difference. Just a guard for a plate that is welded to the face of a box. But that is good to know for other things in future.
Thanks again to all for the help and input! 🙂
-Randy
Inventor 2017 PDS
Message 16 of 50
jletcher
in reply to: rdyson
Yes and no on that.
You have to know what your flat pattern will be and set up a new sheet metal bend deduction rule for it..
Like if I took a 1/8 S/S plate bend it with the bend tool my k-factor will be .001. This will match my deduction in my folding rules..
If I have to add bends using the sheet metal flange in the same part, I just have to remember to set the unfold Options to use my regular unfold rule in the flange command...
This is also how you would use for different radii in sheet metal.. If I have a .125 radii it would have a different deduction then my .500 radii..
So in some sheet metal I have 5 rules for bend deduction..
Message 17 of 50
Mario428
My method would be to create a simple ring, unfold it. make the changes to the flattened part and refold.
Stays as a sheet metal part and K-factor stays consistent
Just an approximation of the part required, easy to edit
Part is done in Inventor 2014
Message 18 of 50
jletcher
in reply to: Mario428
Yes and no..
95% of the time a k-factor you have for bending will not work with a rolled sheet metal. It can be off... It will be close within an 1/8" depending on thickness..
 But again he ask how he would do something I gave him what he ask for.... He did not ask how to make a rolled sheet metal part if he did I would have gave him another way... Smiley Wink
Message 19 of 50
JDMather
jletcher wrote:
 But again he ask how he would do something I gave him what he ask for.... He did not ask how to make a rolled sheet metal part....
Sometimes the OP doesn't know what they don't know and therefore cannot form the best problem statement.  That is the value of a colaboration environment like this.
Message 20 of 50
Mario428
@Anonymous wrote:
Yes and no..
Actually the title of the thread is "Sheet Metal (again!) " and the OP spoke of rolling the part. GRIN
If extreme accuracy is required then a proper K factor has to be calculated for rolled parts.
You are joking right!!!!  I hope so
