In a sheet metal part, if I have two planar faces on different height I can use a double bend option of the bend-tool to connect them from two edges. If the edges of the planes are facing the same direction I can use "90 degree" which creates a two 90 degree bends with given bend radius.
If the edges of the planes are facing the opposite direction I can choose "Fix edges" or "45 degree" but not 90 degree. Why is that?
I can be accomplished the same thing by selecting the "Fix edges" and then adjusting the distance between the two planes until I have two 90 degree bends with the used bend radius but its quite ridiculous that I have to do that in order to get the same result that I would get if I just were able to select the disabled or grayed out "90 degree" button.
I'm using Autodesk Inventor 2015.
Solved by CCarreiras. Go to Solution.
Hi!
To avoid the adjustings, you can first create a flange with the 90deg (any value in length) and then use the bend tool to conect with the 90deg option.
