Can anyone tell me that once you have created a sheet metal part in inventor either folded or unfolded stage and then after creating a 2d drawing (idw) for the part how can you show the bent version and developed version on the same sheet.
What is happening is if i create an idw of the part when it is flattened then this is what shows on the drawing or vice versa,what i want is both on the same drawing.
Regards
When you create the views there is a checkbox to select folded or unfolded. (you must have selected the Flat Pattern in the part file for it to be available in the drawing)
You can place both on the same drawing if desired.
Did you click the Flat Pattern button in the part?
Without that node in the browser - the option will not be avialable in the drawing.
Are you using inventor to automatically unfold your 3d sheet metal model to a flattened state? while I was reading your question, it sounded like you were creating the flat pattern yourself and the 3d model separate.
@methoni wrote:
Hello
What I have done is create a 3d(ipt) sheet metal part (which I can unfold or refold) this is not the problem.
The problem seems to arise when I wish to create a 2d drawing of the same part (idw).
What I would like to do is in the 2d drawing show the sheet metal part in its bent stage and also show it in another view in its development stage ie flattened.
I have been told that this is possible, however when I try to create a flattened view after bringing in a 3d view this option is greyed out.
At this stage this is just an exercise with no dimensions,constraints etc but I do not think that this explains the problem of what I am trying to achieve.
Regards
unfold/refold is NOT the same as creating a flat pattern.
post your part (ipt file) or another sample that you create that doesn't work for you either..
That was my next thought!! you have to use the command " go to flat pattern ". that will create the flat pattern and ungrey that tick box in the idw
Regards
Did you examine the images I attached above?
Do you have a Flat Pattern node in your part browser as shown above?
To select Flat Pattern in drawing you have to have a Flat Pattern in model.
@methoni wrote:
JD
I think the problem is that there is no flat pattern button,...
Incidentally this does seem to be a problem experienced by others.
Regards
Post screen shot.
This is the first time I have heard of this problem.
