Unable to share projects, not using vault just the standard shared projects in inventor. keep gettinr a llock file come up in the file. wondering if there in some way of checking in the file so that my assicate may work on the same project.
Solved by pcrawley. Go to Solution.
I'm assuming this is a double-post - http://forums.autodesk.com/t5/Autodesk-Inventor/Shared-projects/m-p/4391269
There are two fixes:
Hope that helps.
