Inventor Forum
sHARED PROJECT - FILE STATUS CHECK OUT/IN ISSUE
4 REPLIES 4
floccipier
1178 Views, 4 Replies
Hello Guys,
I am trying to use a shared project with my other colleagues. Problem we are having that we are not getting into how to change the File Check in/out Status (option is disabled/greyed) . Do we required administrative rights to do that?
please help.
Note: We don't have vault.
Sajid.
4 REPLIES 4
Hi Sajid,
For changing the status, please do the following.
  • Set the shared project as the active one.
  • Open the file.
  • In the browser, set File Status.
  • Select the file > Right-click.
  • In the context menu, you can check in or cancel the check out, if you are the user that has checked out the file.
  • Otherwise, select Resolve and force or cancel the check out.
Please, find also the attached video for more details.
I hope it helps.
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Hi Alessandro,
Thank you so very very much. really appreciate that. it solved my problem.
Sajid Mahmood
Hi Al,
I need to have experts opinion / peer review of my project settings and other stuff. If possible for you, would be a huge help for me.
Sajid Mahmood
in reply to: alessandro.gasso
Hello Friends,
We also faced same problem, Thanks a lot for guiding.
Yogesh Sapkale
