I just installed inventor 2015 and have been using inventor 2013 for almost two years. I use a 3dconnexion space explorer. When I rotate the assembly and stop abruptly the assembly continues to move a little (almost wobbles). Sometimes it does that and then drops several inches on the screen. This does not seem like a big deal but 8 hours at this and you get a really bad headache and sort of sea sick. My system is Windows 7 – 64 bit, intel 3930K 6 core processor, K2000 PNY 2 GB card (certified), 32 GB ram and 250 GB solid drive with 2 TB WD black all running on a Sabertooth X79 socket 2011 MoBo. I installed 3d space navigator to see if it was my space explorer. This did not seem to help at all. Is there a bug or a setting that could be causing this?
Solved by crkellogg. Go to Solution.
Sounds like both your 3D controllers are starting to die.
My OG SpacePilot was doing the same thing. I wound up just unplugging it. I miss it every time I fire up Inventor at home ...
Rusty
Did you run Calibrate on your 3DConnexion device?
The SpaceExplorer is about 3 years old and the SpaceNavigator was pulled out of the new box to test if the problem still existed. I have never "calibrated" them and never had any issues until now. How do you calibrate it?
Cody
Open the 3D Connexion Control Panel and find the Calibrate button.
Also, I don't think you ever stated in this thread if you tried unplugging the 3D Connexion device and doing so, did or did not resolve the drifting problem.
Thank you for your time,
I have a 3d properties button but not a control panel button in the start folder you show. I can change speeds and set what the buttons do. The drift or motion only happens right when i stop using the 3d device. Its really bad when i zoom in and look at an item but the screen jumps and now what I was looking at is not visible. If I don't use the device I have no issues but my hand is almost welded to that ball. On small assemblies of a few parts (5 to 10) it is a lot less noticeable. Most of my assemblies are 2,000 to 20,000 parts and will rotate very well until I stop.
Thanks again
You don't have a Control Panel screen something like this?
Also, I understand your use of the device, but I still don't think you really answered my question.
If you unplug the device does the problem go away?
It is very important that you not leave anything resting against the puck overnight as it takes hours for the springs to return to steady state.
I have that screen on my laptop at home but not my work computer. It does not do it with it removed. It does not do it with it attached until i use it. It only lasts a second or so after every move. In the 3d start folder i have; home, properties, collage, trainer, and three folders; demos, documentation, drivers. If i move really slow and bring to a stop very slowly it will not jump. If i spin or rotate fast and let go of the ball then it wiggles and jumps a bit. The jump is not just a move but almost an instant translation of the entire assembly up or down on the screen, not somehting a "sticking" 3d device would normally cause. I wish I could put a video of this happening for you to see.
Cody
I might also try un-installing the drivers and installing the latest drivers from 3dConnexion.
I have reinstalled and this still happens. The old 3d software had a calibrate button but the new one does not that I can find. I have now noticed that if zoomed in to one part of the assembly and using the inspect "distance" and then rotate 180 to measure the thickness of a part it will flash to a completely different part of the assembly. This assembly is a factory layout that is about 300 ft long and it will move 50 or 60 ft to a different location. Sometimes it will move back quickly where it should be. I also see a post about filtering the jitter, but i'm not sure where to look for that setting.
I am really happy to have the helpful comments and I will keep trying all suggestions until this is fixed.
I have attached a video I took with my old cell phone, it is very hard to see due to the low resolution. I promise my computer screen is cristal clear. The first few seconds I was showing the jitters but you can't really see them dut to low resolution. The it starts to jump to different places of the layout. I also caught one instance of it jumping to a different place and then within a second returning to the correct location. I am sorry that the picture moves around but holding a cell phone in one hand and using the 3d ball in the other was harder than I thought. Sorry I guess I can't upload a video. If anybody thinks it will help let me know and I will post is somewhere online or email it.
Cody
This is a new machine and a fresh install of IV2015. I am using the same 3d controller that I had on the old PC and I even put it back on the old computer and it's fine (The old system has Inventor 2013). It could be the new computer or the new inventor 2015. The antivirus, network, and 3d device are the same.
