Inventor Forum
Shaft Thread Notes
9 REPLIES 9
Message 1 of 10
mattBA
810 Views, 9 Replies
Shaft Thread Notes
Is there an option that allows me to quickly note shaft thread details similar to the Hole and Thread feature?
Thread Notes
9 REPLIES 9
Message 2 of 10
mcgyvr
in reply to: mattBA
Is that "shaft" generated with the "shaft generator" in Inventor?
Message 3 of 10
mattBA
in reply to: mcgyvr
If I select the feature nothing highlights on the threaded shaft like it does with a threaded hole so I am assuming that feature is for holes only.
Message 4 of 10
mattBA
in reply to: mcgyvr
No, the shaft is a modified shoulder bolt from the Content Center. Only thing I changed was the head so the threading should still be original.
Message 5 of 10
mcgyvr
in reply to: mattBA
Its because your view is shaded..
Message 6 of 10
mattBA
in reply to: mcgyvr
Makes no difference. Tried using a bolt and nut from Content Center and the nut thread highlights but the bolts threading doesn't.
Message 7 of 10
mcgyvr
in reply to: mattBA
IDK.. I don't use content center and don't know how those parts were created either..
Maybe a limitation with CC parts I guess.. seems silly IMO..
I simply model "shafts or bolts" as an extruded cylinder and add a thread.. It easily allows it to be specified with the hole/thread tool.. as shown here..
and actually now that I look at it this image below was a part taken from CC when I first installed Inventor years ago and actually used the CC for a few parts when I was just starting..
Message 8 of 10
mattBA
in reply to: mcgyvr
Found it! Select the drawing view, right-click and select "Display Thread Feature" from the list. That will display the threads hidden lines allowing you to use the Hole and Thread option.
Message 9 of 10
mcgyvr
in reply to: mattBA
well yes.. not sure if its always been that way or not..  I just do that by muscle memory now automatically when I place a threaded part
Message 10 of 10
Phil.E
in reply to: mcgyvr
This is new for 2015.
I have no idea why this is not a default setting, it always has been. I also cannot see how this is helpful, but thanks for finding the hidden solution!
Phil Eichmiller
Software Engineer
Quality Assurance
