Solved by cvbt-thailand. Go to Solution.
Are your members of your ipart generated? Where in the assembly are you not seeing them? In your parts list?
Can you post images of your titleblock in edit mode so I can see what properties are linked to your mass text?
Can I assume that it is the part properties and then the mass pushed into the text?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
