We just switched from 2013 to 2014. I had "Shaded with Hidden Edges hotkeyd to "q" in 2013,but now it's not in the
customize menu anymore? "Shaded with Edges," is there, and my filter is set to all. I would like to have my hotkey back...
Menu: Tools/Customize/Keyboard
Solved by Ray_Feiler. Go to Solution.
It's hidden edge display.
Good question. Am using 2011 and it allows me to assign a key for it, all your service packs for 2013 installed?
Thank you both!
I'm alittle annoyed that the View menu calls it "Shaded with Hidden Edges," and a different menu calls it by another name.
I know what you mean. First I had to search for it then, because of the name difference, make sure it in fact did what you were asking for before posting the possible solution. I'm glad it worked out.
