How can you set by default the ''shades with edges'' visual style by default ? I always work with that visual style, I have to set it every time I open a part or assembly.
There must be a way to do it..
Vinc
Solved by mcgyvr. Go to Solution.
tools..application options..display tab...
check use application settings..
press the settings button and change the visual style to "shades with edges"
