style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<JosephDeluca1017> wrote in messageI'm
href="news:6127858@discussion.autodesk.com">news:6127858@discussion.autodesk.com...
having the same problem on our company's machines. I have attached a
screenshot of the error that comes up. This problems comes up whenever a
drafter tries to open a drawing file. It is also intermittent (sometimes it
opens without any problems). Any help would be greatly appreciated. The only
change we have made to our normal routine is adding a standardised border.
Edited by: JosephDeluca1017 on Feb 19, 2009 4:42 PM
I'm having the same problem when i open the assembly from SAT format and it should be large assly.
Good morning
I have the problem since begening of january
I open a fîle , make some change and when I want to save I got the message , severity error , and when I go to the folder , the file is desapear
what can I do
Thanks for help
G.Galan
I was working on my assembly House.iam (11306 Total occurrences in active document/987 Open documents in session) when suddenly my Inventor 2021 turned off.
When I opened assembly again, I got 4 error messages: SEVERITY_ERROR, facility: <Unknown Facility> ($FFFFFFFF).
I could not edit or save House.iam assembly, I could not make ,,Pack and Go,,, I was just able to export STEP file.
My project option ,,Old Version To Keep On Save,, was on 0, it means I did not have any backup of assembly in folder OldVersions.
I tried many things and at the end I was able to open House.iam without any errors.
I did this:
1. I put ,,1,, In my project option ,,Old Version To Keep On Save,,
2. Right click on House.iam in windows explorer and click on ,,Pack and Go,,. I saved it on another disk. Then I turned off Inventor and turned it on again and I have chosen new created .ipj file as a active project. Then I opened House.iam assembly from new location and I got just 2 error messages: SEVERITY_ERROR, facility: <Unknown Facility> ($FFFFFFFF).
3. I turned off Inventor and turned on again and have chosen .ipj file which I normally use as a active project.
4. I turned off Inventor and turned on again and created totally new Test.iam file and I put into this assembly as a subassembly, my House.iam assembly.
5. I did not get any error messages and I was able to edit and save Test.iam.
6. Then I opened just House.iam and I was able to continue in my work. 🙂
Hi! Please see my reply to your thread.
https://forums.autodesk.com/t5/inventor-forum/severity-error/m-p/10520461/highlight/false#M836554
Many thanks!
Hi johnsonshiue,
I do not need to try things you want me to try because if you read my reply to dan_inv09 again, then you will see in point 6. that I already solved problem with severity error.
But thanks for your effort anyway 🙂
