Inventor General Discussion
Active Member
cj2430
Message 1 of 4 (607 Views)
Settings/ Templates aren't Saving
607 Views, 3 Replies
01-31-2013 04:35 PM
Hey Everyone,
I have recently changed computers, I am apart of a Flexi license system. Now my problem is when i go into Application options and change where to open my templates from it does not save when i quit Inventor. I have also notcied small things like the reverse cusor button i always click but everytime i get out of Inventor it defaults. Does anyone have any thoughts or idea what is going on here? Thanks Alot
(Pictures: One is the custom templates i would like to use. I am selecting them in Application Options/ Templates than applying and closing. Then when i am fnished with Inventor for the day and shut down and the next day when i come back it defaults back to the default templates)
I know it should save because it used to on my previous computer.
00
blair
Message 2 of 4 (598 Views)
Re: Settings/ Templates aren't Saving
01-31-2013 07:23 PM in reply to: cj2430
System information helps, hardware and O/S.
You followed all the pre-requisites for installation:
1.) Logged in with Administrative Priv
2.) UAC slider set to lowest position
3.) Some Anti/Virus software prevents the Windows Registry from updating, so turning the A/V off may be required.
4.) You are using an approved O/S, Win8 is not an approved O/S, SP1.1 will help but not fix all issues.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.75
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
blair
Message 3 of 4 (588 Views)
01-31-2013 10:35 PM in reply to: blair
Check with Task-Manager and see that you don't have another instance of Inventor running. Changes are written when the program closes. If Inventor doen't close properly you changes won't be saved. Possibly try changing your Windows Log-In and see if your exisitng Profile has been damaged. Run Inventor and make the changes and see if they stick.
Win7-64
Delta Tau Chi ΔΤΧ
*Pro
sbixler
Message 4 of 4 (574 Views)
02-01-2013 04:10 AM in reply to: cj2430
As Blair states, App Options are saved when you exit Inventor.  They are saved to the registry in your profile, so this is likely a registry access issue.  It's also possible that Inventor isn't exiting properly, but in that case you should see other indications.
Try logging in with a different account; if that doesn't work, you may have to reinstall with all the steps that Blair recommended.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
