Inventor General Discussion
New Member
392-95380187
Message 1 of 3 (124 Views)
Setting up a point on a different layer to mark the center point of a circle
124 Views, 2 Replies
11-15-2012 11:19 AM
Hello
I need to find a way how to insert a point or a * on the center point of a hole and put it on a different layer. The reason for this is - I am a CAD tech for a welding shop and we cut parts out of steel and we use the dxf file format for our plasma table to cut parts. For example : if i have a 1 inch thick plate and want to put a 3/4'' hole in the plate the hole will be distorted because the hole is smaller than the material thickness. For these situation we can use the plasma table to burn a point or a dot on the center point of the hole. But to do this the point or dot must be on a different layer in the dxf. I  hope this makes sense.
Thanks You if you have any questions you call me @ 1 204 388 6631
Valued Mentor
rhasell
Message 2 of 3 (99 Views)
Re: Setting up a point on a different layer to mark the center point of a circle
11-15-2012 09:35 PM in reply to: 392-95380187
Hi
What you can do is similar to the this thread:
http://forums.autodesk.com/t5/Autodesk-Inventor/How-to-Visibility-off-in-Detail-view/m-p/3664166#M45...
- Create a new layer for the plasma.
- Manually move the holes to the new layer.
   - Select lines
   - Anotate tab; Layer
   - Select the new layer.
If required modify the DWG export template to use the new layers for your purposes.
Reg
Autodesk PDS Ultimate 2015 SP 1 Build 203
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it solves your problem.
*Pro
sbixler
Message 3 of 3 (85 Views)
11-16-2012 04:46 AM in reply to: 392-95380187
Do you think it's wise to use your serial number or contract number as your user ID?  Hope I'm wrong about that, but that's what it looks like.
