I am getting somewhere but there are two things I can't yet do.
1) Set the heading text in the Revision Table to 3.5 mm
2) Set the table text and dimension text to 2.5 mm
How do I make these default for the drawing?
Solved by Frank-Oosterwaal. Go to Solution.
Right click the revision table and select "edit revision table style".
In the style editor you can select different text styles for each.
Click on the pencil to edit the text styles.
In there you can edit the text properties.
Right click the style and select "select new style" to make a new one.
