Inventor 2012.
Is there a way of setting the default values that are displayed in the 'Drawing View' dialogue box?
We wish to make the 'Section Standard Parts' default to ALWAYS rather than OBAY BROWSER SETTINGS.
Ideally I would like this setting to be drawing specific - i.e. can be set via a template rather than require changing settings on each machine - i've seen that you can change it as a global setting in the Application options...
Many thanks,
James
Solved by Cadmanto. Go to Solution.
James,
I have never done what you are asking, but given the fact that these settings don't take affect until views are placed, I am wondering if you can get this set by creating predefined views in your drawing templates. Then in those views set this.
Another thought, like you mentioned these can be set in the application options. With that said, while I have not had any luck doing this, some have. Change these settings on your machine then export those settings and reload them on your co-workers machines.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I can't see any way of doing it outside of application options, unless one of the ilogic gurus knows a trick or two.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks all for your help; I think we'll just go with the Application options setting.
James
