I know I can set default tolerances for an individual part using
Tools --> Document Settings --> Default Tolerance
Can I set similar defaults for all parts, or perhaps for all parts created under one Project?
Solved by CCarreiras. Go to Solution.
Hi!
Yes you can.
Open a new template file, make your tolerance changes and save the file "Save Copy as Template".
Select a new name for this template like "Part_project_x.ipt" or whatever.
Later, When you open a file, you will have the new template available to use and with your definitions corrected.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
