Inventor Forum
Set features to be invisible when create sketch after those 3D features
3 REPLIES 3
lis_wang
865 Views, 3 Replies
Is there any way to set features to be invisible when create sketch after those 3D features so as to make the sketch more easy to see?
3 REPLIES 3
JDMather
in reply to: lis_wang
F7 if the geometry is behind the sketch.
Or right click on Solid Body and turn off Visibility.
lis_wang
Yes, However, if the sketch is between a few 3D features? How?
Thanks. I received many help from you and I am really appreciate it.
JDMather
If F7 doesn't make it clear enough and turning off Visibility of the part is not a good option, then maybe rolling up the end of part marker to a location before the feature(s) might work.  (I use all three of these as appropriate).
2013 (and I think 201) also allow Section Views and View Representations at the part level (used to be only assembly).
