Hello ,
I have a main assembly wish contains a lot of sub-assemblies .
Serveral are also second level sub-assemblies.
Each sub-assembly and also the main assembly wish have ilogic rules , i renamed the default Design representation view to "ilogic" .
But :
Each time i change the model that is driven bij userparrameters in my rules (from a skeleton part) , the Design representationview dont update ??
The associative check is unchecked afhter changes and set to the master view .
Is there a way to set all the visible sub-assemblies to the renamed view " ilogic" and check the associative afther changes ?
Thx a lot for the help .
I had a similar issue. Check my post on a similar topic:
http://forums.autodesk.com/t5/inventor-customization/ilogic-view-representation/td-p/4668063
Hope this helps.
