Try uninstalling service pack 3 from the control panel > add/remove
programs, then reinstall service pack 3 with your antivirus services all
turned off. What version of antivirus are you currently running on this
machine?
If service pack three does not show up in control panel > add/remove
programs, then it is not installed.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
"Dennis Jeffrey" wrote in message
news:5984147@discussion.autodesk.com...
Did you read the 2008 SP3 Readme? There are preparations needed before
installation.
HP zv5000 AMD64 2GB
wrote in message news:5983954@discussion.autodesk.com...
Service pack 3 does not appear to install. After running installation the
instructions indicate to confirm successful to verify version under help
menu, about Inventor.
I have run the install several times and the program still shows SP 2.
