Inventor General Discussion
0 Kudos
Post 1 of 27
Series 11 - Can't install Service Pack 3 or 4
242 Views, 26 Replies
01-23-2012 11:20 AM
I have Inventor Series 11 with service packs 1 and 2 installed. I have been trying to install Pack 3 and I keep getting the windows installer error (see attached). I have read where redownloading the file has worked for others but it has not worked for me. I have tried downloading via both Chrome and IE. I am running XP.
773 Kudos
Post 2 of 27
Re: Series 11 - Can't install Service Pack 3 or 4
01-23-2012 01:25 PM in reply to: gmasters
Are you sure you have the correct version of Inventor SP?
Inventor 11 is alot different that Inventor 2011
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
0 Kudos
Post 3 of 27
01-24-2012 04:22 AM in reply to: blair
The box Reads Autodesk Inventor Series 11
773 Kudos
Post 4 of 27
01-24-2012 08:37 AM in reply to: gmasters
Odd, you are insting SP3 then SP4?
Win7-64
Delta Tau Chi ΔΤΧ
0 Kudos
Post 5 of 27
01-24-2012 08:49 AM in reply to: blair
I am afraid I don't understand. The support site under Inventor Series 11 has SP3 and 4 listed. Are you suggesting it is incorrect?
773 Kudos
Post 6 of 27
01-24-2012 08:55 AM in reply to: gmasters
No, alot of people say they are on IV 11, when they mean IV 2011.
As long as you are correct on your version, all SP's are incremental, you can't install SP2 until SP1 is installed. Double check that you do have SP2 installed before installing SP3.
Seeams like there is something wrong with the Windows Registry, the only solution would be to un-install IV and re-install along with your SP's after.
You should be able to export your settings.
Just thinking, there was a DW* patch, upgrade back then and I beleive if required different Hot-Fixes.
Win7-64
Delta Tau Chi ΔΤΧ
Valued Mentor
18 Kudos
Post 7 of 27
01-24-2012 08:58 AM in reply to: gmasters
Are you using ADMS 2008 as well as Inventor 11? If so have you uninstalled the client upgrade as mentioned on the SP3 download page ?
Note: If you use Autodesk Data Management Server 2008 with Autodesk Inventor 11, please note the following:
Regards
Martin
PDSU 2014 SP1.3
Windows 7 64bit SP1, Office 2007 Pro
Intel i7 980x, 24 Gb DDR3 RAM
Geforce 760GTX Graphics (Diver 337.88)
256GB SSD OS, 80GB SSD working folder
Space Pilot
0 Kudos
Post 8 of 27
01-24-2012 09:02 AM in reply to: blair
1 and 2 installed. I installed 2 back in June.
0 Kudos
Post 9 of 27
01-24-2012 09:12 AM in reply to: Martin_Goodland
I am using ADMS 2011
2,122 Kudos
Post 10 of 27
01-24-2012 09:16 AM in reply to: gmasters
Then why are you using Inventor 11?
I think the first thing you need to do is determine what version of Inventor you are using.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
