Inventor Forum
separating parts that were modified in an assembly
2 REPLIES 2
leomr2
167 Views, 2 Replies
i have an assembly where holes were added in the that state. But I would like to seperate the parts and keep the holes that were added.
2 REPLIES 2
Cadmanto
in reply to: leomr2
Sounds like you added holes as an assembly feature.  Is that correct?
If so then edit the part you want the holes in within the assembly and use the assembly holes as a reference (use reference geometry command) while editing the part within the assembly.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
CCarreiras
in reply to: leomr2
Hi!
I think what you need it´s this app: "Feature Migrator".
It will migrate the  features (holes, extrude, etc) that you do within the assembly enviroment to the parts.
I use it a lot and works well.
Warning: it'a a good pratice to edit the parts later to fully constrain the sketches.
DOWNLOAD IT HERE:
http://apps.exchange.autodesk.com/INVNTOR/pt/List/Search?productline=INVNTOR&query=migrate+features&...=
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
