i have an assembly where holes were added in the that state. But I would like to seperate the parts and keep the holes that were added.
Sounds like you added holes as an assembly feature. Is that correct?
If so then edit the part you want the holes in within the assembly and use the assembly holes as a reference (use reference geometry command) while editing the part within the assembly.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi!
I think what you need it´s this app: "Feature Migrator".
It will migrate the features (holes, extrude, etc) that you do within the assembly enviroment to the parts.
I use it a lot and works well.
Warning: it'a a good pratice to edit the parts later to fully constrain the sketches.
DOWNLOAD IT HERE:
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
