Inventor General Discussion
Valued Contributor
0 Kudos
Post 1 of 4
separate 1 part into multiple parts
1058 Views, 3 Replies
04-04-2012 07:22 AM
attached is a basic IV2012 part made as 1.....can i separate the 2 features and make 2 independant parts from the single part?
If yes can i then use these separate parts and place in assemblies?
Cheers
Terry
Hi Terry__Close,
When you create the features as seperate solid bodies you can use the Make Components tool to derive out each solid body as part files and have them placed into an assembly. To find the make components tool go to the Manage tab.
I hope this helps.
Curtis
Edit the Revolve feature and select the New Solid Option.
Then on the Manage tab select Make Components to push out to individual part files.
1,702 Kudos
Post 2 of 4
Re: separate 1 part into multiple parts
04-04-2012 07:29 AM in reply to: Terry__Close
Hi Terry__Close,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
2,122 Kudos
Post 3 of 4
04-04-2012 07:30 AM in reply to: Terry__Close
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
0 Kudos
Post 4 of 4
04-04-2012 08:27 AM in reply to: JDMather
Thank you,
Terry
