The "bring forward/send backward" commands are only for when you have multiple inserted images to allow you to choose which is on top.
Inserted images will show in front of drawing views.
Hi ericjed13,
Can you describe what your end goal is? I suspect there is a different way to do what you're trying to do, rather than using the image on a drawing sheet.
I hope this helps.
Curtis
I'm not familiar with your requirement, it would be much better if you can attache a sample here.
Based on my understanding, you tried to insert objects (here are images) on the drawing, and the "Bring Forward" and "Send Backward" are workable for inserted images. If you think it's important, you can submit it on Inventor Ideastation.
So far, Inventor support to show decal in part shaded view, so there is a workaround you may have a try.
If anyone has used Draftsight, they know what its all about. Some lines you want on top, and be able to highlight first. Send to Back and Bring to Front commands were used daily when I was using Draftsight.
