I've created a self-draining tube and pipe style for the first time. I find that in some routes only the self-draining style is available and in other routes it isn't available (i.e. in the drop down list or to activate in the styles dialog). The help on tube and pipe is quite poor. Can anyone tell me what the rules are that allow non- or self-draining style selection?
HI!
It's because some styles only have elbows with 90 degrees. You need to have a elbow with a diffeerent angle to use theses styles in self draining (a little more than 90º).
You have to publish a new elbow and carry this on these styles and then they are availables to use with self-draining.
Regards.
Yes. I have a self-draining style defined with custom elbows. I wanted to change a standard route to a self-draining route by selecting a self-draining style. I had to delete the route and start again with a new route. If the route angles are invalid is should (and does) break the route. This can be fixed by entering dimensions with the correct angles. This should have nothing to do with style selection.
Now I want to create a new non-self-draining route and only self-draining styles are available. Why?
It seems you have to make sure the correct type of style is selected before you create the route. Whichever style is selected determines the type of route and you cannot change it. It would be a good idea if self-draining routes had a different icon in the browser.
