If you hold the "Control" key down this should allow you to add items to
your selection, either in the main model window or in the Assembly Browser
window. Another "Widows" selection trick, is within the Assembly Brower
window, if items are in order, click the first upper item, then hold the
"Shift" key down and select the bottom item.
InventorSuite 2010 Suite Pro sp2
Dell Precision 690
Dual Quad Core E5320 @ 1.86GHz
4Gb DDR SDRam - 667 Mhz, ECC
SAS 146Gb - 15k rpm
Quadro FX3500 256Mb - Driver: 191.87 Bios: 5.71.22.55.08
Direct 3D
XP Pro Sp3 3Gb/2800
Space Explorer USB, release: 3.8.3 driver 6.8.1 firmware 3.17
AVG 9.0
wrote in message news:6362201@discussion.autodesk.com...
Is there a setting I am missing that allows you to use your mouse to
left-click, hold and drag to select objects, like in any other autodesk
piece of software. Because I can not for some reason.
Please help if you can. thanks
