When i place a rectangel in a sketch i can't select the parameters to be directly linked to size.
I must first enter a number, delete the number and can then through the triangle to the parameter list.
Is it possible to approach the parameters directly ?
Solved by jostroopers. Go to Solution.
Just type in the name of the parameter that you want to set it to.
When I start a rectangular part, I usually define my parameters in the sketch by typing straight into sketch boxes.
e.g. 'width=100mm" and "length=100mm"
It makes it easier to keep track of parameters in a sketch if you right-click -> Dimension Display -> Expression
I posted a topic in the inventor 2014 beta forum and they wil add it to the list.
