Inventor Forum
Select Other
8 REPLIES 8
Message 1 of 9
j.vanderheijden
787 Views, 8 Replies
Select Other
I work with inv 2012 and zoom with the Space Pilot of 3d Connexion.
If I zoom in or out and I come with my cursor over an object  the view of Select Other comes out  and I keep hanging in the zoom and I can not use more zoom in or out.
I have tried to deselect Select Other but I can not unless I uncheck the wrong button.
Do this under Application Options - General-Selection.
I wonder if this is the Space Pilot or Inventor.
Have the latest drivers installed.
Has anyone experience with this?.
Mvg Jos
Your drawings are only as good as the symbols that complete them...
8 REPLIES 8
Message 2 of 9
xxxr2050
in reply to: j.vanderheijden
Thank you for reporting this.
I’m tried times as you said, but I failed to reproduced it. Would you please give more information, such as snapshot or video, so that I can continue to investigate more on this problem?
Thanks!
Message 3 of 9
j.vanderheijden
in reply to: xxxr2050
I try to make a movie, i'll be backSmiley Very Happy
Mvg Jos
Message 4 of 9
Maybe you need SP1 - issues addressed in Select Other tool
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17534725&linkID=9242019
Asidek Consultant Specialist
www.asidek.es
Message 5 of 9
JDMather
in reply to: MariaManuela
Also click Calibrate on your 3DConnexion Control Panel.
I recommend you calibrate at the beginning of each day or when any problem with user interface occurs.
(particularly if you try to resize the browser and it responds very slowly)
Message 6 of 9
j.vanderheijden
I have already installed SP1 and i did calibrate but that makes no difference.
I made a small movie and made a print screen.
Every time i go over an object white my cursor the zoom action white my space pilot stops.
Here is the link where you can down load the file Zoom where the movie and print screen is in.
http://www.4shared.com/folder/5sB3nZBY/_online.html
Mvg Jos
Message 7 of 9
j.vanderheijden
I was wondering if I can expect a solution very soon.Smiley Sad
Mvg Jos
Message 8 of 9
blair
Try updating your mouse drivers.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 9 of 9
j.vanderheijden
in reply to: blair
After i instaled inv 2012 i instaled also a new mouse driver, this was an beta driver:http://www.3dconnexion.com/supported-software/3dxlabs/3dxlabsapp.html?tx_sugar3dxsoftware_pi1[app_id...
Now i instaled a new driver the problem is over.
This is a bug for 3d Connexion.
Mvg Jos
