I have not seen this. Have you updated for graphics drivers and mouse drivers?
My cursor does the same thing. my right click "select other" doesn't do anything at all as well. every once in a while the little select other selection arrows with center button shows up....but that is usually only in a single part where it isn't really usefull at all. my mouse driver is the most current one....the only other thing I could think it may be is my graphics card. but this select other deal is the only issue I have with my inventor 2011....not sure what to make of it....but this is the first place I have looked for a solution.
@B.OLSEN wrote:...but that is usually only in a single part where it isn't really usefull at all.. .
I use frequently use Select Other on single parts?Especially when doing neutral file repair work.
The CADWhisperer YouTube Channel
I have had the same problem and tracked it down to my ATI graphics card control center.
I you have 'Enable desk top manager' selected then the 'sletect other' icon will jump under the cursor.
If you uncheck this then the situation goes away.
Please see attached screen shot.
Hope this helps.
