Inventor General Discussion
asbuiltjmh1
Message 1 of 7 (431 Views)
Select origin?
431 Views, 6 Replies
10-04-2012 05:47 AM
I cannot select origin to constrain sketch with dimension to origin?
I selected Sketch,
expanded origin,
selected mywork plan (xy)
drew rectangle,
input dims,
right click for marking menu,
selected dimensions,
Origin is yellow,
cannot select it and then edge of rect to set dim that will center sketch on origin?
Just like the videos show, but cannot select origin>
Please advise?
spacebeagle
Project Geometry
What version of Inventor are you using?  This should be automatic.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Yes, mrattray, that in fact was the step I missed.
Thanks again for everyone's input.
spacebeagle
JDMather
Message 2 of 7 (429 Views)
Re: Select origin?
10-04-2012 05:55 AM in reply to: asbuiltjmh1
Project Geometry
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Distinguished Contributor
R.Corriveau
Message 3 of 7 (401 Views)
Re: Select origin?
10-04-2012 09:21 AM in reply to: asbuiltjmh1
You should be able to. Can you post the file with the offending sketch?
asbuiltjmh1
Message 4 of 7 (383 Views)
Re: Select origin?
10-04-2012 03:08 PM in reply to: JDMather
Ver. 2013
Thanks for the input.
I went through the 60 tips.
I appreciate your response and the links to resources!
Jim
asbuiltjmh1
Message 5 of 7 (380 Views)
Re: Select origin?
10-04-2012 03:11 PM in reply to: asbuiltjmh1
Ver. 2013 Inventor Lt Suite to be perfectly accurate.
Thanks.
P.S. Any other thoughts or suggestions will be immensely appreciated.
Jim
mrattray
Message 6 of 7 (354 Views)
Re: Select origin?
10-05-2012 04:33 AM in reply to: asbuiltjmh1
This is for a full version of Inventor 2013, but I imagine LT has a similar option somewhere.
Mike (not Matt) Rattray
asbuiltjmh1
Message 7 of 7 (323 Views)
Re: Select origin?
10-05-2012 09:51 AM in reply to: asbuiltjmh1
spacebeagle
