Inventor General Discussion
Distinguished Contributor
6 Kudos
Post 1 of 8
Secure Pin Component Generator - Can't Select End Plane?
236 Views, 7 Replies
01-17-2013 08:37 AM
Is anyone else having trouble with this DA?
When I try to create a pinned joint, I can't select the end plane for the vertical bar.  Am I missing something?  I've used this DA before, but it was quite some time ago and in IV2013.
Suggestions?  Thanks!
Inventor 2015 64-bit
Win 7 Pro 64-bit SP1
1 Kudo
Post 2 of 8
Re: Secure Pin Component Generator - Can't Select End Plane?
01-17-2013 10:06 AM in reply to: tdswanson
I played with this for a while and I discovered that the end plane has to be on a different component than the original face that you select for the pin.  Looks like the pin would have to be able to go through that face as well.  I hope this helps.
Phillip
6 Kudos
Post 3 of 8
01-17-2013 12:50 PM in reply to: scottph
Yes I figured that the end plane would have to be on a different component, but shouldn't I be able to select the plane that's the "seam" between the two parts?
In the example assembly that I attached, I can only select the end plane that's on the FAR side of the vertical bar, not the side that's really the mating face.
Thoughts?
1 Kudo
Post 4 of 8
01-17-2013 01:35 PM in reply to: tdswanson
I am speculating that the two faces you are trying to select would not cause the pin to go through both components.  If, for example, you are selecting the far positive Y direction face of dummy bar and the mating face, the pin and hole would not penetrate the base at all.  That is why the selection filter excludes it.
This is if I am understanding what you say, of course.
Phillip
6 Kudos
Post 5 of 8
01-17-2013 01:45 PM in reply to: scottph
Were you able to get a pin inserted in the assembly I uploaded?
1 Kudo
Post 6 of 8
01-17-2013 02:25 PM in reply to: tdswanson
Yes, I was.  Unfortunately, though, I am working on 2014 beta, so you I can't send it to you.  I have zipped up a video, though.  Maybe that will help.
6 Kudos
Post 7 of 8
01-18-2013 10:04 AM in reply to: scottph
OK, thanks very much for recording that.  However, that's not necessarily what I would call getting it to work....  Obviously in that example, I wouldn't be drilling a through hole clear from the other side.
Did this DA get broken during the 2012-2013 update?
Paging Autodesk......  Can someone address this?
Thanks!
1 Kudo
Post 8 of 8
01-18-2013 10:45 AM in reply to: tdswanson
If you want to limit the depth of the hole you can use "By Hole" in the placement options, but you have to create a hole first.  Then you can select the mating face as the termination face.
