John sent me his files, and I forwarded the issue to development. BTW, the
hatch lines are there for the 18 mm pitch, but they are so close to the
circular edges that you have to zoom way in to see them.
Loren Jahraus
Autodesk Inventor Workflow Team
"Jmuchow" wrote in message
news:f1a05e9.-1@WebX.maYIadrTaRb...
> A coil spring with a 49 mm pitch diameter, 3 mm coil, 6 revolutions and 17
mm pitch will section in a 2D drawing. If you change the pitch to 18 mm the
hatch lines go away and if you change the pitch to 19 mm the 2D drawings
fails because of, "Modeling failure while trimming and discarding faces."
However, the model does not fail.
> If you change the pitch to less than 18 mm the 2D drawing works again.
> Regards,
> John
