I've created a section view of a 3D assembly and am experiencing problems changing between the display. When orbiting the assembly the section plane appears to cut off part of the model, is there a way to turn off the section plane in the explorer ? Thanks
Solved by JDMather. Go to Solution.
What version of Inventor?
Try right mouse button Done. (the view will still be sectioned)
or
are you referring to a workplane?
if so,
right mouse button on the workplane and turn off Visibility.
