Inventor Forum
section views - background items
8 REPLIES 8
Message 1 of 9
aritter
737 Views, 8 Replies
Is there a way to show only what you cut through in a secion view? In other words, background geometry is not visible. I can turn the individual lines off, but that is very time-consuming.
thanks,
Andy
8 REPLIES 8
Message 2 of 9
in reply to: aritter
If you right click the section in the tree, click
show contents You can shut off vissibility to any components you dont want to
see.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Is
thanks,
Andy
Message 3 of 9
Andy:
In the parent view, the one from which the section was created, show
contents and turn off the visibility of the ones you don't want to see.
Richard
Message 4 of 9
aritter
thanks for the responses.
Actually, I was concerned with a section view of an individual part. I guess there is no quick way in that scenario.
Good to know the choices for an assembly, however.
thanks,
Andy
Message 5 of 9
Basically it can be done by this long method using
a series of "extra" views:
- Create a side view
- create a section view through a point that
divides the part with the arrows pointing towards the half of the part that you
want to use in your final section.
- create another side view by projecting from the
first section ( it will only show the half of the part within your section
definition)
- lastly, create the section view you want by
sectioning from this new projection. (since the unwanted stuff is not seen in
the projection view, it won't show in the new section.)
K
thanks
for the responses.
Good to
thanks,
Andy
Message 6 of 9
acleggEHUKY
You can turn off the background geometry by right clicking the section through view you have created in the tree - select 'Edit Section Properties' - Change the 'Section Depth' from 'Full' to 'Distance' and then set the distance to be anything less than 5 - this will then hide anything that is in the background of the section view
Hope this helps.
Message 7 of 9
johan.degreef
in reply to: acleggEHUKY
Hope this helps.
Almost 20yrs after the question was asked, but in the end we got the correct awnser 🙂
Inventor 2024, Autocad Plant 3D 2024, Vault Professional 2024
Message 8 of 9
acleggEHUKY
in reply to: johan.degreef
I looked on here to find out how to do it. Unfortunately the question hadn't been answered so I figured it out and felt I needed to share 🙂
Message 9 of 9
Thanks so much! Exactly what I was looking for!!!!!
