We have o-rings that were created a while back, and when they appear in an assembly, and we section the assembly, the o-ring does not section. Is there a parameter that can be changed or something else that can be done to correct this, without having to redo the model, since we have numerous that are exactly like this? I have attached an example for review.
Solved by Cadmanto. Go to Solution.
I think the solution to this thread (see attached link) will be the same solution for you.
http://forums.autodesk.com/t5/Inventor-General/Inventor-section-cut-issues/m-p/4576731#M487192
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Right click on the component in the browser.
What options do you see?
You should comment in this thread, not the other one.
It is more pertenant here for future use.
I am glad this woprked for you. Problem solved?
