Inventor General Discussion
Distinguished Mentor
rdyson
Message 1 of 8 (337 Views)
Section View Properties in iam
337 Views, 7 Replies
12-10-2012 12:57 PM
Using half / quarter section view, I know how to section CC parts.
How do I NOT section custom parts?
There has to be setting somewhere. Anyone know?
I guess you are looking for 'participate in assembly and drawing sections' you find this checkbox in the part environment
tools --> document settings --> modeling tab
i hope this helps!
Edit the part you don't want sectioned and uncheck this box in document settings.12-11-2012 8-58-00 AM.png
Cadmanto
Message 2 of 8 (331 Views)
Re: Section View Properties in iam
12-10-2012 01:32 PM in reply to: rdyson
You are talking about something similar to the Display Options under "Section Standard Parts" where you can select which groups you want sectioned except this in assembly mode I am assuming.
Or are you looking for something where you can randomly select individual parts that you don't want sectioned in the assembly model.
Either way I am not seeing anything that does this in the model.  If there is I would like to know myself as well.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
New Member
J.Pieters
Message 3 of 8 (305 Views)
12-10-2012 11:59 PM in reply to: rdyson
i hope this helps!
rdyson
Message 4 of 8 (291 Views)
12-11-2012 06:44 AM in reply to: Cadmanto
Curtis,
There is obviously some setting that allows / causes CC parts to not participate in sectioning in the assembly environment. (see below)
I was looking for a way to make one of my parts behave the same.
john.retzlaff
Message 5 of 8 (287 Views)
12-11-2012 06:59 AM in reply to: rdyson
John Retzlaff
rdyson
Message 6 of 8 (279 Views)
12-11-2012 09:21 AM in reply to: john.retzlaff
Thanks you! Knew it had to be somewhere.
Cadmanto
Message 7 of 8 (259 Views)
12-11-2012 10:34 AM in reply to: john.retzlaff
John,
Thanks for the tip.
It is a shame that this is not built into the actual section command itself, like I have experienced in other softwares.
Where you can select components not to be affected while in the command.
Best Regards,
Scott McFadden
john.retzlaff
Message 8 of 8 (256 Views)
12-11-2012 10:35 AM in reply to: Cadmanto
Yes, sure would be nice if you could change this at the assembly level.
John Retzlaff
